1030 Case overhaul kit
Don Rudolph
08-27-1999 08:37:34
Does anyone know of a source for a 1030 overhaul kit? Case only sells them by the individual parts now and they are quite a bit more expensive than they were in kit form. At least that is what the parts man told me!
Eric
09-13-1999 12:03:15
 Re: 1030 Case overhaul kit in reply to Don Rudolph, 08-27-1999 08:37:34
Don't know if for sure if you can get a KIT anywhere but we just rebuilt our 1030 and got all the parts individually. 830 parts are the only ones that will work for your 1030. the heads, sleeves, pistons, injectors are all the same. So are the connecting rods and push rods. Rocker arms are different but will intermix. 1030 are steel and 830 are cast.
Wayne Reed
08-27-1999 20:50:53
I have an Overhaul Kit that I bought for a "600" diesel only to find out that it fit a 930 diesel. I can't find out until Monday if it will fit your tractor. It is a "McCord" gasket set VG-6735-3 , also 51-5113 pan set, and BS-252 rear seal. These three make the complete set. If you can use it let me know. It cost me almost $180. for them.
Jerrie Lott
08-28-1999 09:25:43
 Re: Re: 1030 Case overhaul kit in reply to Wayne Reed, 08-27-1999 20:50:53
The overhaul set from a 930 will not fit a 1030 a 1030 is 50 cubic inches bigger the bore spacing is wider so the heads are different so most of the gaskets won't even interchange.
