1370 clutch questions
Sam Mosher
12-02-2004 14:12:36
My '77 1370 is having some clutch issues. It doesn't seem to be disengaging completly. I can't get it into gear unless I really pound it down to the floor hard (at which point I usually hear the engine pull down momentarily like it's ready for me to shift) and when I do finally get it into gear it doesn't want to shift between forward and reverse on the powershift unless I do the same thing. Also, the pedal doesn't want to return up (engage) without help. What could be causing this? Mal-adjusted clutch or ??
case trader
12-04-2004 18:30:50
 Re: 1370 clutch questions in reply to Sam Mosher, 12-02-2004 14:12:36
i think they had a series of linkage &swivle joints that were bad to wear hard to get adjusted 1270 had it i know just before they came out with the cable operated clutch i had trouble when i got it to release then it was out the other direction trial an error.
behrens
12-04-2004 15:16:15
could you post linkage adjustment? having same problems with 1570. thanks
AllanC
12-02-2004 20:45:09
You could have sticky valves in the valve body, but it could just be the linkage from the pedal to the valve body sticking or binding. Blow the dirt out of there and see if can be freed up. And yes, they like to stick. There is also an adjustment length for the valve position but my book is out in the shop. If you need it i'll post it tomorrow
Sam Mosher
12-04-2004 19:37:00
 Re: 1370 clutch questions in reply to AllanC, 12-02-2004 20:45:09
If the valves are sticky then what? What's the worst case scenario do you think?
case trader
12-05-2004 14:18:10
 Re: 1370 clutch questions in reply to Sam Mosher, 12-04-2004 19:37:00
hey dad always said do the easy stuff first.i'm sure it will be linkage adj. if you feel like it is a valve remove the body get some little trays i like to number punch every plug an keep it to the same location clean every thing polish the spools i like to use my drill for this put it together an go i pull the center plug first remove spring an steel ball use two studs to hold everything in place when removing an replacing.
