1948 CASE LAI picture
DC DENNIS
12-30-2004 19:09:37
third party image
FINALLY GOT PICTURES, HOPE THIS WORKS
Chances R
12-31-2004 07:02:14
 Re: 1948 CASE LAI picture in reply to DC DENNIS, 12-30-2004 19:09:37
third party image
Industrial tractors are cool!
Big Al's Acres
12-30-2004 19:15:24
Nice tractor, was it a military tractor? I have an LAI-M that I am trying to put back together. Do you have any spare parts?
Alan
DCDENNIS
12-30-2004 19:14:18
third party image
PICTURE #2
DCDENNIS
12-30-2004 19:17:46
 Re: 1948 CASE LAI picture in reply to DCDENNIS, 12-30-2004 19:14:18
third party image
PICTURE #3
Big Al's Acres
12-30-2004 19:17:25
What size rubber do you have on the rear? 23.1 x 30"?
DCDENNIS
01-01-2005 08:26:33
 Re: 1948 CASE LAI picture in reply to Big Al's Acres, 12-30-2004 19:17:25
LAI HAS 23.1X 26 REAR TIRES, THE ONLY PARTS I HAVE
ARE THE REAR WHEEL WEIGHTS, ABOUT 845 LBS.EACH OF WHICH I PLAN ON PUTTING BACK ON IF I NEED THE WEIGHT, DO NOT KNOW WHAT WEIGHT CLASS I CAN RUN IN.CHANGED OIL IN ENGINE, DONT KNOW WHAT WAS IN THERE, GOT ALMOST 5 GAL OUT, NEED TO CLEAN OUT CARB, AND ADJUST REAR CHAINS,AND REPLACE THE HYD BRAKE MASTER CYL PACKINGS AND BLEED THE BRAKES WILL SKID SOME FIRE WOOD, TO GET THE BUGS OUT, DCDENNIS
Big Al's Acres
01-01-2005 08:34:21
 Re: 1948 CASE LAI picture in reply to DCDENNIS, 01-01-2005 08:26:33
My LAI-M has the 800 plus weights also. I can not use the 23.1 x 26? But I do plan to use 23.1 x 30's. Wish my LA was up and running but with any luck and some work I may make it by fall. I need to find a left foot pedal as mine was robbed.
Al
