188d tank type block heater
G.B.
01-09-2005 08:29:30
Anyone install a block heater on a 188d? Bottom radiator hose seems too short for that type.(530ck)
mEl
01-09-2005 09:31:11
 Re: 188d tank type block heater in reply to G.B., 01-09-2005 08:29:30
Tank type heater, remove plug by the fuel filter base, Install a fitting to accept a 5/8 inch heater hose, route to bottom of heater, make sure there is drop in the hose to the heater, remove temp sender on rear of head on the opposite side of the engine, install a nipple and tee, install sender in one opening on tee and a fitting to accept block heater outlet hose. try to keep upsweep in this run, will work fine , have done many that way, mEl
G.B.
01-09-2005 14:34:51
 Re: 188d tank type block heater in reply to mEl, 01-09-2005 09:31:11
Thanks, mEL. Honored by a response from one of the elite! You along with quite a few others have helped me in rebuilding my 530CK. Appreciate it,Gary
