1951 VAC Torque Tube Question
WOD
01-13-2005 13:08:32
Hey Guys,
Onto my next issue, I have to keep adding oil to the torque tube every so often in my VAC. I think it's going into the tranny. Does the oils
discolor when they run together? Anyone had this problem before?
Thanks
Sam#3
01-13-2005 15:36:45
 Re: 1951 VAC Torque Tube Question in reply to WOD, 01-13-2005 13:08:32
As per the lower post check the transmission level.
Another good bet if you have a low pressure hydraulic pump it could be passing oil to the engine.
Is there a leak in the hydraulics any where?
WOD
01-13-2005 18:45:47
 Re: 1951 VAC Torque Tube Question in reply to Sam#3, 01-13-2005 15:36:45
There is no leak anywhere and the oil level in the engine does not change.
Paul f
01-13-2005 13:21:15
It can Probably would not change color of rear end fluid as there is a lot of it realtive to the amount leaking in. Is the rear end getting over full???
WOD
01-13-2005 18:49:02
 Re: 1951 VAC Torque Tube Question in reply to Paul f, 01-13-2005 13:21:15
I have not checked it recently as I had to drain it out to replace the diff axle seal. The brakes were getting oiled up. But I do remember several
years ago I noticed that I had to keep putting oil in the torque tube and then when I checked the tranny oil level, it was past the full mark.
WOD
