1210 DB hydraulics
doug
09-07-1999 13:44:24
I have a leak on the lever for the back hydraulics on this thing. It's the lever by the 3 pt. lower/lift handle. It's leaking out the front like there is too much pressure there, or a seal is gone. Is this hard to repair? Also on the left hand side of the tractor as you are sitting down, there is a 3 position lever. Is this a by-pass valve of some sort? What position should it be in? Thanks for any help.
Elmer
09-07-1999 15:31:07
 Re: 1210 DB hydraulics in reply to doug, 09-07-1999 13:44:24
Sounds like you have a remote detent blown out. Some parts for that detent are no longer available through Case.
