1957 311B help
jpbm
02-02-2005 06:18:25
Hi all, my 311b has rear end fluid leaking out from around the brake pads. I took off the brake cover and brake pads, fluides are coming from around the gear/shaft. (not sure the name) I am no pro but im sure it shouldnt be leaking fluid there. What is the best way to repair it.I have the parts book I can see the seal but not sure the best way to get them replaced. Plus were to get them. Thanks for any help. P.S. Not sure if anyone remembers this but this 311b has a swinging 3 point on it. It was broke when I bought it. After some work I got it up and going and it works great. Thank again, Jake
jon from mn
02-02-2005 09:44:31
 Re: 1957 311B help in reply to jpbm, 02-02-2005 06:18:25
you have to remove the entire brake assy. behind the brake pads you will see a removable housing, held in by about 5 bolts. you have to remove this housing. the bearing and seal are accessible from the back side of this housing. just drain the oil down below this housing, remove the bolts and pry the housing out. the shaft should stay put. make shure you save any shims that may be behind the housing. if you change the bearing you may have to re-shim for propper end play in the shaft.
