2290/no go
case trader
02-03-2005 04:43:26
2290 power shift i was driving down the road when it just stopped pulling hydraulics all work steering works no trans power push clutch in no noise does the hyd. run off the flywheel or limiter clutch? haven't checked the press. at the body yet leaning toward the limiter clutch any thoughts.
Joe Prince
11-29-2005 20:08:21
 Re: 2290 power shift will not come out if Hi in reply to case trader, 02-03-2005 04:43:26
Power shift is stuck in Hi, I replaced the filters and this made no differance.I need some help!! Thanks Joe
Gpurrs
02-03-2005 16:39:51
 Re: 2290/no go in reply to case trader, 02-03-2005 04:43:26
I would think you would not have hyd or steering if torque limiter is out.Somebody correct me if Im wrong.
John Saeli
02-03-2005 06:02:59
Hey Trader: Is the P/S on that 2290 electric? The same thing happened on my 2094 & it was a fuse. Doubtful the 90 series had electrics yet, but worth checking out.
case trader
02-03-2005 17:07:12
 Re: 2290/no go hey john in reply to John Saeli, 02-03-2005 06:02:59
no electric shift,guess i'll opener up,you ever had to replace the printed circuit board in the console? i called dealer to order one on a 2096 he said it was the second one that week.
DKase
02-03-2005 05:26:17
That is exactly what happened when my 2090 torque limiter crapped out. If you have the ability to split the tractor it is not a big job. LOL DK
