1940 Case DC-4 Generator/Mag!!!
Geral Vaughan
02-08-2005 12:03:50
I have a 1940 DC-4 with no mounts to install or pulleys to power a generator. This tractor has lights and electric start but no generator. I have been told I will need the inline generator system which goes in between the mag and govenor housing. Would anybody know who to contact or where I should go to try to find this set up.
Don L.
02-09-2005 16:11:18
 Re: 1940 Case DC-4 Generator/Mag!!! in reply to Geral Vaughan, 02-08-2005 12:03:50
I have that generator set up. Meant to post here, {not so much under Todds post}. No biggy.
Don L.
todd hamilton
02-08-2005 19:00:33
Some of the others with DCs may be better abled to answer this question but SCs (I have a '44) have the generator mounted on the left-front side of the engine and run on the fan belt. The generator pulley serves as the tension idler for the fan belt. Mounts would not be real apparent if the hardware has been removed. There are two threaded holes on the SC block at rear of the generator and a "scissor" bracket at the front to adjust the belt tension.
Don L.
02-09-2005 15:43:28
 Re: 1940 Case DC-4 Generator/Mag!!! in reply to todd hamilton, 02-08-2005 19:00:33
I have that set-up.
Don L.
Gerald Vaughan
02-10-2005 07:02:07
 Re: 1940 Case DC-4 Generator/Mag!!! in reply to Don L., 02-09-2005 15:43:28
Don l, is it availible fore purchase, or do you know where I can locate one????
