Hey Elmer
mEl
02-11-2005 16:25:58
Elmer, mEl here, Do you remember a while back Larry from Penna. coming to you for help on a 1200 that would go up as soon as starting the engine. Adjusting the spool travel with a indicator and replacing some shims under the abutment plate he had removed fixed the problem, I also resurfaced and reseated the check valve, it had a really deep groove, works fine now. Thanks for the info, mEl
