1971 Case 580CK Gas Engine Rebuild Kit
Dan Archambault
02-14-2005 12:18:57
Hello,
I was wondering if anyone knew where I can purchase a complete engine rebuild kit for a 1971 Case 580CK which has a Gas engine. Complete meaning Crankcase, all Gaskets etc...
Thank you for your time.
just 580's
02-14-2005 18:39:19
 Re: 1971 Case 580CK Gas Engine Rebuild Kit in reply to Dan Archambault, 02-14-2005 12:18:57
Complete; Sleeves, pistons, rings, wrist pins, rod & main bearings (to match your crankshaft grind) and a complete engine overhaul gasket set with front and rear crankshaft seals. If that sounds like what you are looking for follow the link below.
Dan Archambault
02-15-2005 06:50:43
 Re: 1971 Case 580CK Gas Engine Rebuild Kit in reply to just 580's, 02-14-2005 18:39:19
Thank you very much for the reply. Are you refering to the link on this web page? I didnt see a web site on your post. I did look at the rebuild kits they have but i am also in need of a oil pump and crank. The engine is a 4cyl gas but not sure on what kind of engine it is. Thanks
