1951 Case VAC Rear End Cleaning
WOD
02-16-2005 07:41:25
Hey Guys,
The oil in the rear end was very milky when I drained it. I want to wash/flush it out before
adding new oil. Should I use diesel fuel or something else like kerosene?
Thanks,
WOD in VA
WOD
02-17-2005 07:35:45
 Re: 1951 Case VAC Rear End Cleaning in reply to WOD, 02-16-2005 07:41:25
Thanks Guys for the response.
todd hamilton
02-16-2005 14:31:41
I used kerosene on my SC with good results - more important to have many buckets close by!:^)
Joe (Wa)
02-16-2005 10:26:22
It will work ok. When you drain the present oil and again when draining the cleaner, tilt the tractor each side to help drain all the liquid out of the axles. Give it some time to drain each side, gonna be slow in cold weather.
Joe
Augie
02-16-2005 09:21:08
Either one will work. Probably cost a bit less $$$ to use diesel.
C. Amick
02-16-2005 09:14:51
I think I read somewhere that the milky look is caused by water getting into it. I agree that either kerosene or diesel fuel should work fine for cleaning.
Arthur
02-16-2005 08:51:06
Either one of those should be fine....
