1953 vac 14 case
David Anthony
02-16-2005 20:29:38
I have found a 1953 case vac 14 that is in very good condition I would like to knowif anyone knows the horse power. This tractor has new rebuilt engine new paint an decals how much would be a good price.Thanks for any information.
C. Amick
02-18-2005 09:24:22
 Re: 1953 vac 14 case in reply to David Anthony, 02-16-2005 20:29:38
It will pull a 2-bottom 12-inch plow and run a 5ft. bush hog. It has to be around 20 horsepower. Value depends on where you live. i would guees it is worth between $1,800 and $2,500. You probably couldn't get $2,500 for it here in WV, but you probably could get $2,500 or more for it in other areas where Case's are more popular.
Sam#3
02-17-2005 06:18:17
Go to the top of the page and access the Case forum. In the sidebar you will see a 'VA profile.'
It states sixteen HP. I've read some say as high as twenty-two with the gasoline engine.
Camboted
02-16-2005 20:55:45
third party image
I bought this 1952 VAC-13 with the new scraper/scarifier for $1900 last fall out of Northern, WI. The engine runs fine, but is not overhauled and does blow a little smoke at start up.
David Anthony
02-16-2005 21:55:51
 Re: 1953 vac 14 case in reply to Camboted, 02-16-2005 20:55:45
Thanks for the information do you know the horse power. I have a 1966 ferguson To 35 it is a powerful little machine. I really like this case a would like to know a little more about vac14 I have made several trips to look at this tractor hear it run drive it my friends say I should just buy it. I was looking at it before I bought the ferguson I need a tractor to work.
Camboted
02-16-2005 23:55:03
 Re: 1953 vac 14 case in reply to David Anthony, 02-16-2005 21:55:51
If your tractor has just been overhauled it may well have oversise pistons. It is not as powerful as the Ferg. TO35. I would guess it at 25-28hp.
