530 backhoe value
MN Cal
02-18-2005 11:38:32
I was wondering what a 69 530 backhoe would sell for, Engine runs good, starts fast, smokes very little. loader and hoe operate good, small leak in a couple hyd. cylinders. tires are good, looks clean. brakes questionable. also has new head gasket. Info greatly appreciated.
chvet73
02-18-2005 13:24:03
 Re: 530 backhoe value in reply to MN Cal, 02-18-2005 11:38:32
I sold my diesel 530 for just under $6000 last year. It was in good shape. I saw one advertised this morning which was gas and said it needed a little work. They wanted $4000 for it. I've seen them from about $2500 to $6000. Hope that helps some.
MN Cal
02-19-2005 15:04:58
 Re: 530 backhoe value in reply to chvet73, 02-18-2005 13:24:03
Thank you, I forgot to say this one is diesel also. I dont know if that makes it worth more.
BKahler
02-19-2005 21:53:40
 Re: 530 backhoe value in reply to MN Cal, 02-19-2005 15:04:58
I paid $2800 for a 63 530CK diesel backhoe. Engine was knocking when I bought it, turned out to have a bad rod bearing which trashed the rod and crank. The rebuild is costing me more than I had planned but I still think I got a good deal.
Brad
GandSRanch
04-25-2005 19:25:21
 Re: 530 backhoe value in reply to BKahler, 02-19-2005 21:53:40
How much less would a gas model be worth? Do they perform any different or just cost more to run? Thanks
Brad K, I like the pictures on your site! Please post more and can you comment on the progress. How is it trying to find parts? I'm looking at something similar. Thanks again, Greg
