1962 Case diesel won't go!
ZANE
09-12-1999 04:22:46
A man down the road came to me and asked me to come look at his Case tractor. It wouldn't go. He had taken it apart at the clutch housing. At the rear of the transmission housing and had the shifter out and the lift was off the tail end of the tractor. When I got there he was going to show me how he could turn the shaft going into the rear part of the transmission with no resulting movement of the wheels. When he turned the shaft I was at the back of the tractor and saw that the ring gear turned and the side gear to the right rear wheel turned but the wheel did not. The axle was broken just past the side gear to the right axle. When I told him this he didn't believe me. It took me 10 minutes to convince him.
Moral of the story: Know where you are going befor you start a trip.Or,:How not to diagnose the problem!
