Case 600 diesel
Mondo
02-18-2005 21:20:32
Our town is having a homecoming party this summer, and one of the attractions is going to be an antique tractor pull. My grandpa has a 1957 600 that has been idle for around 12 years now. I am mainly a John Deere guy but this Case has a special place in my heart, and I know it's got alot of life left in it. I don't think it would take a whole bunch to get it going again. What kind of pulling potential does this tractor have up against say...an 830 JD.
comfortking
02-19-2005 05:06:12
 Re: Case 600 diesel in reply to Mondo, 02-18-2005 21:20:32
If rules call for stock tractors and they all weigh the same and it is a low gear pull the 600 will hold its own against any brand.
Mondo
02-19-2005 07:53:24
 Re: Case 600 diesel in reply to comfortking, 02-19-2005 05:06:12
It is for stock tractors only, 1960 and older. This 600 has the cast weights rear wheels too.
case930
02-19-2005 16:37:05
 Re: Case 600 diesel in reply to Mondo, 02-19-2005 07:53:24
Hi I had a 1959 case 900B with a full set of rear wheel weights In 1st gear in stock puuls I was never beat I pulled agents a lot of 830 and 720 JD and w-9 IHs and alwes wow a lot of fun!! If I can get my scaner to work I will post a pic.
Thanks Nick
Mondo
02-19-2005 22:51:34
 Re: Case 600 diesel in reply to case930, 02-19-2005 16:37:05
Sorry for my ignorance, but is a 900B approx. the same size as the 600.
caseman-d
02-20-2005 09:57:08
 Re: Case 600 diesel in reply to Mondo, 02-19-2005 22:51:34
third party image
Case's first diesel was the Case mosel 500. It featured a 377 cui engine which was introduced in 1953, In 1957 Case added 2 more forward gears, increased rpm, and added the eagle to the front radiator and renamed it the 600. Also in 1957 they gave the 600 new sheet metal and renamed it the Case model 900. The 900 also had the 377 diesel, rotory pump, 6 speed trans., and also increased rpm. They made 1515 case 600's and 750 Case 900's in 1957. In 1958 Case changed the model to the 900B and after a certain serial number they went from a rotary pump to an inline pump. All 59 900B's should have the inline pump.
caseman-d
eman-d/For%20Sale/100-0069_IMG.jpg>
case930
02-20-2005 07:10:28
The 900 was the same tractor as a 57 600 they only made the 57 600 one year and came out with the 900 in 58 and 59 with defernt skin that is the only defernts.If you need any more help just ask. Thanks Nick
Mondo
02-20-2005 10:04:51
 Re: Case 600 diesel in reply to case930, 02-20-2005 07:10:28
Thanks guys.
