Case 1500 Uniloader
Fred Hekking
09-14-1999 11:00:20
Hi, I saw your web page and I am hoping that your expertise can help me. I have a 1966 Case Uniloader 1500. I have had it for about 15 years. Unfortunately, some kids poured sand in the gas tank and engine. I rebuilt the motor and as I was going through the process I found out that the motor is an MVG4D. Apparently, this is a military version of the motor. The problem I have is that I can't find any engine rebuilding books for this motor. I have the mechanical assembly complete but I don't have any ideas on the Magneto set up or the firing order. Do you know if there are any manuals available for this motor. It is a Wisconsin V-4, Model MVG4D. Spec No. 249734 Serial No. 4071875. I don't know if you need all these numbers but any information would be helpful. If someone can point me in the right direction, that would be greatly appreciated. Thanks
Jerrie Lott
09-15-1999 19:54:14
 Re: Case 1500 Uniloader in reply to Fred Hekking, 09-14-1999 11:00:20
Your best bet is to either find your closest "Wisconsin" dealer or go on line and search for "Wisconsin engines". The owners manual will usually tell for engine service refer to (whatever the engine is when it is not the same as the unit)
