2290 Powershift problem
KYCase
03-10-2005 12:27:17
I have a 2290 that stays in reverse untill the engine rpm is above 1000 to 1200 after that it shifts and pulls ok. If you idle the tractor back down after running in a forward gear (does not matter if it is in 1,2or3) it will try to go from foward to reverse and then back to foward (Frog Hopping) untill the clutch is pushed in. Anybody have any ideas. Thanks KYCase
turbo
03-10-2005 15:42:21
 Re: 2290 Powershift problem in reply to KYCase, 03-10-2005 12:27:17
This may sound strange, but does your power steering work OK. The return flow from the steering and brake circuit returns past the cold oil relief valve and then to reverse lockout spool. A problem with the steering pump or circuity can cause such a symptom as your steering return flow decreases at lower RPM.
