31, 32, 33 hoes
Mac
03-12-2005 09:29:47
What are dig depths and weights? Are bucket and dipper cylinder sizes different for each model?
Dennis/Ohio
03-14-2005 02:53:45
 Re: 31 pictures in reply to Mac, 03-12-2005 09:29:47
#31 loader & hoe. 1700 lbs lifting capacity with boom & dipper at 90 degrees
Dennis/Ohio
03-13-2005 18:04:45
 Re: 31, 32, 33 hoes in reply to Mac, 03-12-2005 09:29:47
I can answer some of your question.
I think they all dig 14ft with standard hoe. Extend-a-hoe would be more.
#31 has swing cylinders mounted high and out the rear. digs great but easily hit when moving large items.
The biggest diference to you is the cylinders did get bigger and the hoe heavier in weight and weight handling ability.
Mac
03-14-2005 05:29:38
 Re: 31, 32, 33 hoes in reply to Dennis/Ohio, 03-13-2005 18:04:45
Thanks Dennis. Do you know the weight of the 31 hoe attachment alone? I'm looking into fabbing a mount on a 7000lb skip loader. I think the 33 is an xt-a-hoe model and would be a little heavy, but 31 or 32 should be a nice fit.
Dennis/Ohio
03-14-2005 12:55:12
 Re: 31, 32, 33 hoes in reply to Mac, 03-14-2005 05:29:38
#31 should be approx. 3500lbs
