188D/207D starter drives
jdemaris
03-14-2005 09:59:50
I'm replacing the 188 diesel engine in my 580CK backhoe with a newer 207D engine. The starter drive for the original 188 has 9 teeth. The starter drive for the 207D starter has 10 teeth. So, I got checking part numbers in my 580CK book for the 188 engine, and it shows both - 9 and 10 tooth, depending on certain options like hydraulic shuttle shift, clutch driven, etc. So, I'm a little puzzled. Parts book shows the same tooth and part number ring-gear, regardless if a 9 or 10 tooth drive is used. I've bolted up both starters, and both appear to mesh well. It seems that one must mesh better than the other if the tooth count is different? If the matching ring gear was different, it would easily make sense - but there is only one ring gear for either drive. I kind of hate to find out later that under load when cranking, the wrong starter-drive gear is going to screw up the ring-gear. Anybody know any more about this?
Jim B
03-14-2005 10:37:43
 Re: 188D/207D starter drives in reply to jdemaris, 03-14-2005 09:59:50
I also noted the same variation in the design of Case starters drive gears for the 188-207 engine family ... The knowledgable Case parts guy at my local dealer said that the different usage was between Gas or Diesel applications. Either will properly mate with the ring gear because both 9 & 10 tooth drive gears are the same pitch diameter. The 9 tooth design effectively increases the torque the starter can place on the flywheel due to gear ratio change. Therefore the 9 tooth is Diesel, 10 tooth is Gas... per my dealer.
jdemaris
03-14-2005 12:41:17
 Re: 188D/207D starter drives in reply to Jim B, 03-14-2005 10:37:43
Thanks for the replies. My industrial Case dealer is not sure about the drive applications. He thinks it depends on the nose used on the starter. My 580Ck parts book shows both drives being used on both gas and diesel and making the difference when the machine has a hydraulic shuttle shift or a dry clutch drive. The idea of less teeth having more torque makes sense. The newer starter, with the 10 tooth drive, appears to also be a higher-torque starter because the housing is different and probably has bigger field coils in it. Housing is one large diameter all across, whereas the older 188D starter has a stepped down housing with two diameters. So, maybe with the newer starter, what it looses with the extra tooth, it gains back with bigger fields - and thus spins the engine faster than the original 188 9 tooth starter? I'm not a Case expert. In fact, this is the first industrial Case I've owned and worked on. I've been a Deere mechanic most of my life. I kind of like the Case better than most Deeres I've worked on. I'm not sure if it's the change I like, or the machine's design. The smaller Deere engines used the same sort of small frame Delco diesel starters. We got them in two versions - the stepped down housing was called a "700 amp" starter, and the one-diameter housing was called a "900 amp" starter. Maybe I've been overthinking all this, but again - I'm not a Case expert. I bolted both starters up, and both appear to mesh okay. I don't want to have to pull the engine out later and replace the ring gear.
WAYNE J
03-14-2005 10:22:35
on that searter drive. I HAVE FOUND THAT 1 tooth will not make any difference just make sure the outside gear and depth are the same. Wayne J
