2470 3-point
Bob Sand
03-28-2005 21:12:13
I just purchased a 2470 the 3 point wont lower any suggestions on where I should start also the tractor seems to steer hard is this normal,I realize there is a lot of weight there and was wondering if the 2 could be connected, also I think this tractor was stored for a while but everything else works and runs fine,a real clean and good looking, and running tractor. thanks for any info
TripleRange
03-29-2005 09:14:34
 Re: 2470 3-point in reply to Bob Sand, 03-28-2005 21:12:13
I had the same problem with my 630. I used a skid loader to push them down with the valve in lower position like John says. After about the third time they went down on their own. Good luck!
John Saeli
03-29-2005 04:37:05
Hey Bob: I had the same problem with a 4690. The linkage was all seized. With the engine off, and the valve in the Lowering position, we used a Loader to push it down.
