CASE ?
gary case
03-29-2005 11:55:42
HE SAYS 530 DESIL "67 SER#2003613 CAN'Y FIND IT. JUST WENT UP FOR SALE. FAIR SHAPE,NEEDS SOME TLC,FRONT END LOADER,BRUSH HOG AND BLADE, FAIR SHAPE.PWR STR,PTO,THREE PT,HOMEMADE ROPS.WANT TO BUY IT. WHATS IT WORTH? APXXX. HE WANTS 3700.00 REAR TIRES GOOD FRONTS ARE HUGE INDUSTRIAL LOOK ING. THANX GARY
Camboted
03-29-2005 15:30:31
 Re: CASE ? in reply to gary case, 03-29-2005 11:55:42
Location is everything! But the price sounds fair to me. You'd spend more than that for a new loader, and it wouldn't ne as strong.
gary case
03-30-2005 03:48:08
 Re: CASE ? in reply to Camboted, 03-29-2005 15:30:31
thanx ted i knew i could count on you for some support about this tractor. i'm just wondering about the ser #.2003613 '67 case desil. must have wrote it down wrong,cause i can't find anything even close. they all start with 8306501.i'm going to have to go back and check it out closer. have a great day!
gary case
03-30-2005 14:15:48
  530 DIESEL CASE HELP in reply to gary case, 03-30-2005 03:48:08
BUYING THIS 530 BUT THE REAR END FLUID IS PERTY MILKY,YELLOW LOOKING. IS THIS WATER AND A BIG PROBLEM OR JUST A FLUID CHANGE? BEEN SITTING OUTSIDE. LOADER WORKSUP AND DOWN BUT THE TILT IS SLOW TO NOTHING. SAID IT WORKED FINE AND EVEN HAS DOWN PRESSURE. CHECKED HYDRO FLUID (NOT RUNNING) AND SHOWED FULL. IS THERE ANOTHER PLACE TO CHECK? HAS TRACTOR HYDR CONTROLS AND ONES ON LOADER.IS THERE ANOTHER WAY TO MAKE THIS TO OPERATE ONLY THE LOADER? NOW YOU HAVE TO HOLD ONE DOWN AND CONTROL THE OTHER. THANX FOR ANY HELP GARY
wayne2
04-02-2005 18:20:30
 Re: 530 DIESEL CASE HELP in reply to gary case, 03-30-2005 14:15:48
Gary, Bucket cyl. can be rebuilt, but use loader for a while if pump is bad all of it will slow down and thats $$. Luck
