2590 Plates
JakeBos
03-30-2005 06:43:46
Are there any other plates besides the pto plates in the rear end? Cus im finding lots of broke friction plate peices in the back end and its plugging up my tranny filter.
Randy N
03-31-2005 21:46:28
 Re: 2590 Plates in reply to JakeBos, 03-30-2005 06:43:46
PTO plates were a common failure,but the friction material is a burnt orange color.C1,C4,diff lock, and brake plates are all black. If you remove the shifter housing from the right side of the trans housing , you can see the suction screen. That might give you a clue to what is shucking friction material.
Can't even use my name
03-30-2005 18:44:25
Torque limiter. Put it in gear (4th I think) and hold the brakes and see if it slips or kills the engine. We just had one where the Belleville spring went bad and let the torque limiter slip till it was ate up one one side. It keep plugging the filters then bypassing them and plugging up the brake cylinders in the steering valve. I would say most likely it is the torque limiter though.
turbo
03-30-2005 16:13:26
Differential lock and brakes. If bronze, dif lock.
JakeBos
03-30-2005 20:46:44
 Re: 2590 Plates in reply to turbo, 03-30-2005 16:13:26
hmm ya the stuff thats coming out is black carbon plate peices
THaden
03-31-2005 04:37:51
 Re: 2590 Plates in reply to JakeBos, 03-30-2005 20:46:44
Brakes
just did my 2390 last winter. does the brakes on the tractor work? what about the dif lock? my brakes stopped working correctly just before the tractor would not move or steer because the brake lining plugged up the tran screen. just my experience. love that tractor.
THaden in NW IN
JakeBos
03-31-2005 17:10:20
 Re: 2590 Plates in reply to THaden, 03-31-2005 04:37:51
Hmm the breaks seem pertty strong we can do full circles with them
