1210 David Brown: Bogging Down Under Load
Blackjack
04-08-2005 08:43:27
My 1210 started bogging down under a load yesterday. Replaced the Fuel Filters and it helped a little but still doing it. Ordered a new Screen ($5.00) for the lift pump and a new Air Filter ($55.00). Any other suggestions as to what might be causing this to happen? Also, does that Air Filter not seem a little high?
JRT
04-08-2005 20:35:00
 Re: 1210 David Brown: Bogging Down Under Load in reply to Blackjack, 04-08-2005 08:43:27
That Air filter does seem a little high priced. I bought one last year for my 1200 for 25.00.
Elmer
04-08-2005 14:21:17
Remove the fuel lift pump and pull out the push rod on the camshaft. If it has a concave on the end replace it. Your not getting enough stroke on the pump to supply full fuel.
joe e-tx
04-08-2005 09:10:22
try blowing air from lift pump line back to tank might have sediment in tank pick up line. my 995 does this more but my 1210 does some times.
joe
Clive
04-09-2005 13:01:33
 Re: 1210 David Brown: Bogging Down Under Load in reply to joe e-tx, 04-08-2005 09:10:22
My 1200 did this and an old man known as "duck S$%T Mcaye" told me to replace lift pump valves did that fine now!
Mr Mcaye was very famous in Caterpillar circles in Africa.
