1971 580CK Case Steering question??
walkom
04-12-2005 10:42:21
I was dumping a load and the steering wheel jerked to the right and then no steering at all. When i placed the front bucket on the ground and lift the front wheels off the ground and pull on the wheels the steering wheel moves. but when I turn the steering wheel nothing moves( the wheels). Any ideas??Thanks
just 580's
04-12-2005 21:46:19
 Re: 1971 580CK Case Steering question?? in reply to walkom, 04-12-2005 10:42:21
Check the steering cylinder piston seals. Even one cylinder by-passing will cause a failure.
walkom
04-13-2005 06:08:30
 Re: 1971 580CK Case Steering question?? in reply to just 580's, 04-12-2005 21:46:19
I think you are right. My father started from the steering wheel and worked his way down./ He checked the hand pump and manifold. he was getting ready to take the power pump (power steering pump) off. i suggested it was the pistons. I couldnt open the steering cylinder illustration. thanks for the help.
