1956 case model 400
Howard Junkin
04-23-2005 14:28:11
i am looking at a 56 case model 400 s# 5517XXXcs it has had in chasse overhual about 8 years ago. they didnot change the front or rear main seals. now i'm told the rear main is leaking. the problem is the oil is coming out by the started. could the bellhousing be that full of oil? also whate would this do the cluch? is there a drain hole in te bottem of the bellhousing that could be pluged? they are asking 900$ for it. it has hdy, small bucket,snow blower,and drag blade from a smaal cat dozer, the carb needs rebuilding. and it need a good tune up the tin work is in good shape but badly faded, tires are in fair to good sabe with rear chains and tirs have calsume cloride in them. does this sound like a good buy? ballpark figure price on replasing thes seals? tanks howard junkin. hjunkin@up.net
Pat Tercho
04-24-2005 05:38:43
 Re: 1956 case model 400 in reply to Howard Junkin, 04-23-2005 14:28:11
Howard, your serial number doesn"t add up if this is a big 400, should be 806XXXX-810XXXX. Your number sounds like a 1951 model year tractor, like a DC or SC? If I recall right those tractors had clutches that ran in oil. Maybe one of the guys who knows about them will chime in. Good luck with it.
