1175 Main bearings problems
Wideload
04-24-2005 11:53:54
While working this spring with our 1175 Case the oil pressure was a little lower than normal was still in the green area of the gauge. It rained today so we checked it out. Gauge is OK, Oil pump OK, all rod bearings look good had proper clearance checked with plasticgauge. Took the main bearings down the 4 wide ones all looked good with proper clearance. The 3 intermediate narrow main bearings all worn to the copper lining with over 0.10 clearance. Can anyone explain why this happened? Thank You
c hess
04-26-2005 16:19:22
 Re: 1175 Main bearings problems in reply to Wideload, 04-24-2005 11:53:54
Are bearings origional . if so how many hrs? IF tractor was overhauled AN YOU DONT KNOW HISTORY I WOULD CHECK DIAM ETER OF ALL THROWS AN MAINS . IF OK REPLACE WITH ALL NEW ONES. D ONT KNOW WHY yours are worn like that.
