1030 heads
steve marston
04-30-2005 19:23:33
i want to put a turbo on my 1030, ans switch to the direct injection heads of a 70 series case. Is this all possible?
Paul D
05-10-2005 19:30:25
 Re: 1030 heads in reply to steve marston, 04-30-2005 19:23:33
If you want to put on a turbo you could look around to see if anyone has a MW turbo set up. As for direct injection you you would probably be better off swapping motors out of a 70 or 75 series case.
THaden
05-02-2005 04:16:51
Two ideas: the 1200Tk had indirect fuel injection but it had a turbo. or you could switch the motors from a 70 sereies tractor.
but combining motors from the 70 & 30 series might be more $$$ and duress. my humble thought
we have a 1030 with a 1200tk motor in it. pulls like a sonof gun. cant keep the front end down.
THaden.
Thad
05-01-2005 04:19:31
Yes it is but you will have to change alot of stuff. You need to find 1175 get all the top end stuff plus the rods and pistons. You will have to have custom inj lines made to go over the top of the engine to fit. Hope this helps. Thad
