1030 lift arm problems Help please
Tom O'Dowd
05-13-2005 14:55:21
The lift arms will not stay up when operating tractor however the remotes work ok .The fluid was changed about a week ago I thought that was the problem but it was not any help please
CK RICHARD
05-13-2005 18:28:34
 Re: 1030 lift arm problems Help please in reply to Tom O'Dowd, 05-13-2005 14:55:21
did you check your draft control to see where it is sat at?
Wayne J.
05-14-2005 05:43:14
 Re: 1030 lift arm problems Help please in reply to CK RICHARD, 05-13-2005 18:28:34
Hay Tom does 1030 have an external cylinder?? if it does the piston seal / o ring may be leaking by. lift something with the draft control ( off ). see if it stays up. if it coast back down its probably the cylinder. ?? my thought. Wayne J.
