1200 david drown over reving
sharpie
05-21-2005 04:10:52
My 1200 david drown revs up real fast as soon as I start it. Is it the govenors ? If so what do I have to do to fix it? It has a simms injection pump.
Ida Stickler
05-21-2005 19:45:26
 case tractors in reply to sharpie, 05-21-2005 04:10:52
How do I tell how much a 1954 Case tractor is worth. My boyfriend has one that needs work and a mag or this mag recharged.
Elmer
05-21-2005 07:46:38
 Re: 1200 david drown over reving in reply to sharpie, 05-21-2005 04:10:52
Check the oil level in the pump first. If you have to try Dexron oil in it first. If all fails the governor has to be looked at.
sharpie
05-21-2005 09:36:00
 Re: 1200 david drown over reving in reply to Elmer, 05-21-2005 07:46:38
How do I get at the governor,and what might be wrong with it?
Elmer
05-21-2005 10:59:34
 Re: 1200 david drown over reving in reply to sharpie, 05-21-2005 09:36:00
You have to completely dismantle the pump. Better to take it to an injection shop!
