1170 trans oil level
charles hess
05-28-2005 19:23:29
Neighbor has a1170 . Anyone now how to check trans oil level other than by glass sights on side ? I had 1070 that had same thing an nmever had to much trouble seeing if full or low but oil is a different color in his tractor . Glass shows both glass same oil color- not clear indicating low. He is depending on me an i dont want to misslead him!
c hess
05-30-2005 13:05:21
 Re: 1170 trans oil level in reply to charles hess, 05-28-2005 19:23:29
Neighbor with 1170 found out you can turn glass sights out of transmission . Found both glasses were coated with scum giving false full reading!!! cleaned them an put back in an was only gallon an half low. Lucky i guess.
c. hess
05-29-2005 04:43:25
Thanks big orange.
big orange
05-28-2005 20:51:54
The sight guages are the only way to check the oil.The glass will look a different color if the oil level falls.
