1937 Case L clutch / transmission teardown
cheg
05-29-2005 15:33:01
I need to split my L to find the noise coming from the clutch / transmission area. I used a stethoscope to listen to the bearings while the clutch was engaged. The shaft bearings sound fine, but I think the engine clutch shaft bearing is the problem. Any pointers before I start? I have split other tractors and have the manual. Does the first reduction shaft (belt pulley) seem to have bearing problems? Any help would be appreciated.
AllanC
05-29-2005 18:38:13
 Re: 1937 Case L clutch / transmission teardown in reply to cheg, 05-29-2005 15:33:01
The Clutch shaft bearing is the usual culprit. If you need gears I have used ones. They are easy to split, 'cause there's no linea, wires etc to speak of. Just heavy. Work careful.
