1370 3pt falling
Can't even use
06-10-2005 20:24:49
Recently acquired two inexpensive 1370's, one with a busted crank and one with a nasty growl in the rearend. Ended up with a decent $3500 1370 and a free complete parts tractor! Anyhow, the 3pt will fall as soon as you shut her down and while running they fall just a bit then raise back up constantly. What gives?
Thaden
06-13-2005 04:18:46
 Re: 1370 3pt falling in reply to Can't even use my name, 06-10-2005 20:24:49
Shane,
you still have parts for a 400 western? i remember a while back you thought you might from reading one of your responses to a message. we got a 400 that is missing the the rad, rad supports, grill, hood and more. looks like you made out godd one the 1370"s. you are in the south bend area right? I use to be in the USMC reserves over there. lot of good times. good luck
tremayne hadenfelt
chesterton IN
hadenfelt(at)comcast(dot)com
06-13-2005 18:49:23
 Re: 1370 3pt falling in reply to Thaden, 06-13-2005 04:18:46
Yes I am in the SB area. I have a 400 but not sure if it is what you need. Email me and remind me cause I tend to forget stuff lately.... busy building a house and farming. You can come and look at it if you want just need to set up a time.
Roger H
06-11-2005 05:38:12
I had that happen to my 1370 several years ago, it was metal filings getting on top of the 3 point pistons & tearing up the seals so the oil went past the seals. The sleeves & pistons stand upright at the back of the tractor rear end, crawl under & find a pair of square plates probably at least an inch thick & maybe 6 inches square, they drop out the bottom which makes for an easier fix, you dont have to tear way into the rear end to solve this problem. Mine has been rock solid since replacing the sleeves & pistons.
