900 drawbar
DC-Casey
10-06-1999 20:35:46
I'm building a 3-point hitch for my 900. Most of the weight will be carried by the angle iron frame that holds up the drawbar. Will this handle a ton or so? I think it should as the hitch on a spreader or mixer must be at least that heavy.
Thanks,
DC-Casey
spf
10-06-1999 21:34:56
 Re: 900 drawbar in reply to DC-Casey, 10-06-1999 20:35:46
These draw bar brackets were one of J.I CASE's downfalls. An engineering failure one might say. Under continuous use with larger spreader Or the mixer, there is a fair chance the bracket will fail.
On several occasions I have seen on most of these brackets were. The owner of the machine has done at least some modifying Weather chaining them up or welding etc, So you may want to watch how much strain/ load is put on it.
Anyway whatever you decide knock yourself out
