1961 Case 310 Plantery Gears
Paul Coskery
07-11-2005 23:16:20
My dozer will not move when put in gear unless both brakes are pulled back.I took the back cover off and the gears look good and all are turning.The shafts going to the sprockets also turn.There wasn`t much oil in the rear but everything looked good.If it is not the planetry gears what else could the problem be?Thank you.Paul.
