1030 Hydraulic Problems
Anderson
07-13-2005 20:24:33
We have a 1030 case and hydraulics are not working. Have changed the filters, one was really dirty...but it still does not work. Any ideas???
case931
07-14-2005 13:40:34
 Re: 1030 Hydraulic Problems in reply to Anderson, 07-13-2005 20:24:33
You might check the intake tube that goes to the bottom of the transmission case. It has a screen on it and mine was completely submerged in dirt/grease/crud. I found it when I took the PTO housing off to rebuild. I subsequently replaced ring and pinion and that is when I cleaned out the transmission case. I don't know of an easy way unless you drain and fill up with diesel - although that wouldn't have fazed mine it was so bad. It was a terrible long job but I was sure glad I did it after what all I found down there.
