1090 Case tractor
Dale Garver
07-28-2005 14:13:34
A 1090 case is up for auction.Its only the 2nd one I have seen.Was it built same time as 1070 ?Was it an oddball tractor?
WALTER
07-28-2005 21:30:55
 Re: 1090 Case tractor in reply to Dale Garver, 07-28-2005 14:13:34
WHEN I WAS A KID WE HAD A 1090 CASE IT HAD POWERSHIFT. IT LOOKED JUST LIKE A 1070 EXCCEPT IT WAS MORE POWERFULL. AND HAD BIGGER TIRE'S.WOULD KICK BUTT TO.WE USED IT FOR THE TRACTOR PULL'S IN AREA'S AROUND US. FACTORY TRACTOR NO CHANGE'S. IN MY BOOK I GIVE IT A PERFECT 10 AS TO CASE'S REVENGE ON OTHER TRACTOR MANUFACTURE'S.FOR SIZE WEIGHT AND POWER IT WAS THE NUMBER 1 TRACTOR OF IT'S TIME.
Ohio Case
07-28-2005 20:45:25
When and where"s the auction????
Tom (Ks)
07-28-2005 17:36:18
Built only a couple of years. Heavy duty tractor, heavy front axle, solid 3pt hitch and thick drabar. Makes a good loader tractor. Power shift and eight speed.
big orange
07-28-2005 16:56:58
I believe it was built at the same time,believe they were an 8 sp instead of powershift.Can't remember if they had outboard planetaries or not,don't think they did,but not sure.
oldl
07-29-2005 13:34:54
 Re: 1090 Case tractor in reply to big orange, 07-28-2005 16:56:58
Big Orange,
They were offered with either the 8 speed or the powershift, and used a bar axle instead of the outboard planetaries. I understand that they were only built from 1970 thru 1972, and fewer than 500 were built, with the majority of those built during the 1970 run.
oldl
big orange
07-29-2005 16:55:00
 Re: 1090 Case tractor in reply to oldl, 07-29-2005 13:34:54
Had never seen one with a powershift,didn't know that.
