400,730--power steering leak
Ron
10-11-1999 18:18:58
I have a 400 and 730 which both appear to have the same power steering units. Both are leaking oil somewhere in the front which looks like it may be coming from the power steering units. Oil constantly drips down from the front nose piece in front of the radiator at a slow rate. Does anyone have any experience with this on these models or any tips on where it may be coming from? Is it hard to fix? Any information would be helpful and appreciated. Thanks.
Shaun In wisconsin
10-13-1999 19:25:32
 Re: 400,730--power steering leak in reply to Ron, 10-11-1999 18:18:58
Are both of these machines CASE O MATIC? If yes check to see if the Lines going into the radiator, in front of the radiator.The two lines that go in the bottom are oil cooling lines for your torque converter, and yes I have seen this on certain occations.
gmp
12-26-2000 10:33:58
 Re: Re: 400,730--power steering leak in reply to Shaun In wisconsin, 10-13-1999 19:25:32
Try using Lucas Power Steering Stop Leak. Gauranteed to stop leaks. www.GimmeLucas.com
