1966 Case 930 Western Special Comfort King tire si
BI
08-04-2005 17:57:20
Got a 930 western special comfort king that came with 18.4 x 34 inch rubber. Is it possible to put 23.1 x 34 inch rubber on this tractor? Could you order it from the factory with 23.1's? Are the fenders adjustable? I have 23.1's I thought I could put on but they look quite large. I hope they wll fit. Any help would be great. Thanks
PamND
08-07-2005 18:01:20
 Re: 1966 Case 930 Western Special Comfort King tir in reply to BI, 08-04-2005 17:57:20
Hi:
Our 1966 Case 930 has 23.1 x 30 tires and when needed we have some clamp-on duals which are 18.4 x 34 in size. The overall height of both sets of tires are almost the same. The 23.1 tires has a 20 inch rim. The fenders are not a problem.
We have no information on 23.1 x 34 tires.
Pam
Jim McVay
08-07-2005 07:05:24
There was a 930 on the Cover of Antique Power a few years back that had 23.1 x 34 tires on it.
CK RICHARD
08-05-2005 15:50:14
BI I'm looking at my buyer guide from 1966 for 1030 case tractor western fenders are ajustable up and down 3 inchs, standard rear 15.5-38 optional 23.1-30 or18.4-34 from case . row crop fenders are not ajustable, my 1030 has 18.4 -38 and they will not fit under the fenders .
DKase
08-06-2005 05:05:00
 Re: 1966 Case 930 Western Special Comfort King tir in reply to CK RICHARD, 08-05-2005 15:50:14
If you look close on the inside of the fenders you will notice 2 sets of holes. The fuel tank needs to be removed, and the fenders lifted and bolted into the lower set of holes. The fuel tank brackets go into a lower set of holes also, and the fenders set higher. In the high set 20.8 x 38's clear in good shape. I have them on my 930. DK
CK RICHARD
08-06-2005 10:07:58
 Re: 1966 Case 930 Western Special Comfort King tir in reply to DKase, 08-06-2005 05:05:00
Not on my tractor only one set of holes row crop
DKase
08-05-2005 10:40:09
The early 930's had 23.1 x 26" tires. The 34's would be really really tight under the fenders. The row crop 930's did come with 23.1 x 30's, 18.4 x 34's, and 18.4 x 38's. The fenders on the row crops were adjustable. The standards were not. Good Luck. DK
Lamont
08-04-2005 21:37:37
I've seen many old 930s with 23.1s on them down here in this rice country. Fenders should have enough adjustment to clear. I can't remember what width rim is needed for a 23.1. Maybe someone else can help you on that.
