188 D black smoke
timg
08-07-2005 05:29:25
Well its been 2 years since I posted a message about excessive black smoke on my rebuilt 188 backhoe motor (can"t beleive that) I wanted to wait til the motor broke in and it has 122 hours on it now and still smokin. I have checked both the timing mark on the flywheel and the marks in the pump window. Both line up TDC. I had to alter a 9/16 box end wrench to loosen the back bolt on the timing pump to advance the timing.I turned the pump about 1/8 inch CCW if sitting in the seat. started it up and I could hear a change right away. It sounded alot stronger and just more like what a new diesel engine should sound like. (if that makes any sense) Anyway It seems like the smoke was less I will have to run it a while before I say for sure. Thanks
Roger (Mi)
08-07-2005 08:09:07
 Re: Timing it late in reply to timg, 08-07-2005 05:29:25
The correct timing for a 188D is (4) degrees BTDC.
(Before Top Dead Center) Set the flywheel timing mark to 4 degrees BTDC then align the marks in the fuel injection pump window. Remember, as you look through the flywheel openning, the DC (Dead Center) mark will be BELOW the 4 degree BTDC indication mark. Good luck. Thanks chess.
Old Rusty
08-07-2005 08:06:43
 Re: 188 D black smoke in reply to timg, 08-07-2005 05:29:25
188 in 580s time at 8btc and 480s time at 4btc.
This should help with smoke and power
timg
08-08-2005 12:09:29
 Re: 188 D black smoke in reply to Old Rusty, 08-07-2005 08:06:43
So Which way do you turn the pump to retard the timing. CW or ccw sitting in the seat?
It sure sounds good where its at!
c hess
08-07-2005 07:13:25
Rodger can help you from mi . I THINK SOMETIME BACK had trouble an timing isto be 9 degres btdc .not sure though.
