188D won't start hot, starts reluctantly cold, con
NHkeith
08-09-2005 08:22:47
Thanks for the help in figuring out my engine start problems. On advise I have removed the fan and radiator and have taken the cover off the injection pump gear. At top dead center with number one intake and exhaust valves closed the injection pump gear looks to be 180 degrees off. My question now is there a corresponding mark or dot on the timing gear as well as the injection pump gear to align to? My book shows a index mark but, I can't seem to spot it on the gear tooth. My guess is if the injection pump is timed 180 degrees out it would start but only be fueled to 2 cylinders and be seriously out of cue on the compression stroke. Should I dig deeper and take the complete gear cover off to check the crank gears as well (much more work)
Thank again
Keith
Phil (NJ,AZ,Sask)
08-11-2005 22:50:23
 Re: 188D won't start hot, starts reluctantly cold, in reply to NHkeith, 08-09-2005 08:22:47
"My question now is there a corresponding mark or dot on the timing gear as well as the injection pump gear to align to?"
I recall that there is an indented dot on both gears... It should be noted that the half-moon Shaft key is prone to shearing. The Shaft also has a locator(Hole),on the pump side, tang that must be alligned correctly (Hole to Hole)with the inside drive slot.
Hope This Helps,
Roger (Mi)
08-09-2005 20:44:28
 Re: What are you doing? in reply to NHkeith, 08-09-2005 08:22:47
Since the firing order of the 188D is 1-3-4-2, it cannot run if it's 180 degrees out of time. The injection pump would inject #4 when it should be injecting #1. Since you can get it to run, that means the timing cannot be that far off. The timing of a 188D should be either 4 degrees BTDC (Before Top Dead Center) or 8 degrees BTDC. Usually, there is a decal on the tappet cover telling the proper setting. Always check the simple things first. Why replace an alternator when it's just a loose belt. Don't tear your engine apart until you've made a proper accessment of the problem. It may be as simple as setting it to the proper timing. Make sure #1 is coming up on the compression stroke. Look in the inspection hole on the bell housing for the timing marks. Depending on the engine, stop turning it when it reaches the proper timing mark. Turn off the valve on the fuel tank. Remove the small timing cover on the injection pump. The two lines inside should align. If they're out of alignment, loosen the three bolts holding the pump to the timing gear housing and turn the injection pump until they do. Cranking speed for a diesel is very important too. It must be at least 200 RPM. At that speed, the engine should have 400 PSI of compression with no more than 25 pounds difference among the cylinders. Good luck.
