VAC engine miss
1031D
08-14-2005 23:11:23
I rebuilt a VAC over the winter. It runs like crap. I put new sleeves, pistons, cam, valve train, bearings, ect in it, and it would run perfect for about 2 minutes then burn the points. I installed an elecronic ignition setup and still runs like crap. What did I miss? It is still 6V positive ground.
F-I-T
08-15-2005 13:49:23
 Re: VAC engine miss in reply to 1031D, 08-14-2005 23:11:23
You might want to check the distributor bushing. VAC's that I have worked around almost always have excessive play in this area.
Frank
1031D
08-15-2005 09:15:14
I would run the tractor for 1-2 minutes, and the points would burn again and again. I bought a Pertronix setup from the nice folks here, and it still runs like crap without points to burn. Could something be stuck in a carburator nozzle? I put a kit in the carb after it soaked in carb cleaner for a couple days.
Sam#3
08-15-2005 05:52:13
You didn't say what had been done to/for the ignition and fuel systems. Burned points is indicative of an open capacitor.
WALTER T.
08-14-2005 23:55:14
WELL YOUR PROBLEM IS THE VAC IS NEG GROUND. AND POINT SETTING IS .015 MAGNETO AND .020 POINT'S AND I HOPE I HELPED YOU.
Paul f
08-15-2005 07:04:14
 Re: VAC engine miss in reply to WALTER T., 08-14-2005 23:55:14
Unless it was converted VACs came from factory with Positive Ground. (Unlike DC/SC of same vintage...go figure)
Is the coil a 6 volt coil and is it wired correctly for positive ground (+ to dist ...- to switch)
