Help Please Case 431 hydrolics for discs
Manny P 2
08-18-2005 10:45:42
This is an emergancy please anybody if ya can help please do..... I bought a case tractor I belive its a 431 any how when i looked at it and checked the hydrolics it was fine, but after we got'er home she sat about 3 weeks and when we checked the hydo fluid it was empty so i bought a 5 gallon tub and put about 3 to 4 gallons in then tried the hydrolics and they don't work, seems tohave no presure.....any one thanx....manny
Roger (Mi)
08-22-2005 19:39:04
 Re: Are you using the three-point? in reply to Manny P 2, 08-18-2005 10:45:42
If you're using the three point and the rockshaft piston seal is leaking, you're dumping hydraulic oil into the rear end. Check the oil level in the rear end. If it's over filled, you'll need to pull the rockshaft cover, remove the rockshaft piston, and replace its seal.
