CASE TRACTORS
SHAWN D
10-16-1999 18:31:06
AFTER THE DEATH OF MY FATHER I HAVE COME TO HAVE SIX CASE TRACTORS, WICH I CANNOT FIGURE OUT WHAT THEY ARE OR WHEN THEY WERE MADE.THEY STILL HAVE THE REGESTRATION PLATE ON THE DASH.CAN ANYONE HELP ME? MOST I BELEIVE TO HAVE BIN BUILT IN THE 20S TO THE LATE 40S
Chris Vangel
10-19-1999 00:36:04
 Re: CASE TRACTORS in reply to SHAWN D, 10-16-1999 18:31:06
Shawn, at the left of this screen you will see the heading 'specs and values', click on the subject 'more...'. On that page you will find the heading 'serial numbers', write down the serial numbers you have, they are on the plate on the dash. You should be able to tell model designation and year produced from the tables in this page. Hope it helps, Chris.
Larry
10-17-1999 17:32:26
You can buy a good case book in the book section of Yesterdays Tractores.The one that would have the info you are looking for is " 150 Years of J.I.Case" by C.H.Wendell.If you don't want to go that route Contact me at lwfure@webtv.com ,and give me the model,and seriel number that is on the vintage tag and I will see what I can find for you.I have a copy of the book I mentioned,and can look up the info for you.
Gretchen , Library Director
11-09-2000 14:56:44
 Re: Re: CASE TRACTORS in reply to Larry, 10-17-1999 17:32:26
If you need the book, go to your library. If they don't have it, they usually can get it on interlibrary loan. This is normally a free service or you pay postage. While you're there, check our the Chilton's. Your library is a great, free source of much material. Good luck.
Ken
10-18-1999 15:26:07
Would like ignition and engine specs for a Case VAC. Got the tractor running,"but" it back-fires through the carbuetor. I rebuilt the carbuetor and it runs now. Also the generator is putting out 6.47 volts. Is this about right?
Jim
02-29-2000 07:16:42
 Re: Re: Re: CASE TRACTORS in reply to Ken, 10-18-1999 15:26:07
Just e-mail me, People call me case man. I have dozens of VAC's and they all run. I have lots of specs and tech. data that may be of use.
