213S 2-way moldboard.
Hurley J. D.
08-30-2005 15:04:14
I need a operaters manual for a Case 213S 2-way moldboard. Any help out there.
daj
08-31-2005 12:17:16
 Case 800B in reply to Hurley J. D., 08-30-2005 15:04:14
My cousin owns a Case 800B that is in very good condition. It has been in a shed in NW Iowa but hasn't been run for 4-5 years. It has very good tires and tin but heis not sure if the engine is froze up. He also has a mounted corn picker, a 4/16 plow and a 4-row cultivator for this tractor. He would like to know how much each item is worth. I have a friend who is interested in the tractor.
Hurley J. D.
08-30-2005 19:49:33
 Re: 213S 2-way moldboard. in reply to Hurley J. D., 08-30-2005 15:04:14
The 213s is a 3- bottom roll over plow. Three point hitch. You can plow in one direction and turn it over with a hydraulic rotary actuator and plow back in the other direction, without going around and around the field as you have to do with a regular moldboard.
South Texas Case
08-30-2005 21:27:20
 Re: 213S 2-way moldboard. in reply to Hurley J. D., 08-30-2005 19:49:33
Do you have a picture of this plow that you could post. I have one I'm trying to identify. I have a couple of mine, but have to wait for the college son to come home and show me how to post them. Thanks Tony
Hurley J. D.
09-02-2005 13:10:16
 Re: 213S 2-way moldboard. in reply to South Texas Case, 08-30-2005 21:27:20
Hello South Texas Case, if you will send me an e-mail, I will send you a source possibley for a manual for your plow. I just talked to a man and he said that the only manual he had for a case 2-way plow was a 213C. He described the plow and I think that it is maybe the same as mine and also yours. I ordered the manual. Will have it within 2 weeks.
Hurley J. D.
08-31-2005 07:41:30
No I cannnot post a picture, no scanner or camera, but if you will go to the Case IH dealer and get them to look on the computer you will find a picture, also they can print out a parts list and illustrated parts break down.
Tom Railsback
08-30-2005 17:27:09
Is this the wheeled plow with 2 bottoms? If so, I need a manual too. I was able to locate a dealers service and set up mauanl on e-Bay and should have it in a couple of weeks.
