VAC Brake Shaft Seals
M5G
09-09-2005 17:32:31
Does anyone know the seal size/make etc for replacing the seal between transmission and brake shaft area for a VAC Case with disk brakes? I have one leaking need help finding right seal before I tear into it....also tips on how much trouble it is to replace them would be appreciated. I know in previous posts some have been replaced; and I'm hoping to get some idea as to seal number and make...Thanks.
F-I-T
09-09-2005 18:02:33
 Re: VAC Brake Shaft Seals in reply to M5G, 09-09-2005 17:32:31
M5G:
PAul F. compiled a seal chart that I keep on my website. It shows the seals as VT3465, crossing to a new number of A30501, which is the Chicago Rawhide (CR) number 22446, which is the National number 450316, which he shows a price paid of $8.51.
You should be able to get them at NAPA using those numbers. BTW, at NAPA, they have a seal book which lists a bunch of the CASE numbers. That helped when I rebuilt my VAC.
On the seals, the differential quills can be removed so you can service the seal. You might have to jiggle a rear wheel to make the differential climb into position when you reinstall the quill, but that should not be a problem. Or, you can use a slide hammer with a screw tip and yank them out and tap the news into place.
Frank
m5g
09-10-2005 17:09:50
 Re: VAC Brake Shaft Seals in reply to F-I-T, 09-09-2005 18:02:33
That's what I needed--thanks for your info!
