1954 case sc PTO
Merle Mclaughli
09-12-2005 06:19:54
I have a 1954 Case SC model and the pto clutch slips under a small load, Where can I buy a clutch disk for this model and also a manual for this year tractor, I cant see anyway to adjust the clutch so I assumed it would need a new disk. Thanks
Camboted
09-12-2005 06:27:00
 Re: 1954 case sc PTO in reply to Merle Mclaughlin, 09-12-2005 06:19:54
Good news and bad news. First the bad. Your tractor dosn't have a pto clutch disk, but a series of brass plates like an automatic transmission and you don't want to buy them. That's the bad news. The good news is, you can adjust the pto through the square cap behind the seat over the hydraulic sump. Remove the plate and then (Very carefully)remove the locking pin and then rotate the adjusting collar one notch at a time (clockwise facing the PTO shaft) until it takes 50 pounds of pressure at the end of the control handle to engage it.
