2390 hydraulics intermittant
paulbick
09-14-2005 09:03:31
Still having problems on 2390 (14,000 HRS) with hydraulics failing to respond unless we dump the clutch or shift into 3rd pwr shift. We have had dealership replace hyd. pump, control valve springs, cleaned suction screen, replaced power shift clutches as needed and changed clutch spools. Steering is ok, brakes work fine. 3 pt hitch and remotes are the trouble. Fluid and filters have been changed each time.
dwag
09-15-2005 10:55:58
 Re: 2390 hydraulics intermittant in reply to paulbick, 09-14-2005 09:03:31
problem is in C1 circut,bad feeder tube or cracked C1\C4 housing.
paulbick
09-15-2005 14:49:28
 Re: 2390 hydraulics intermittant in reply to dwag, 09-15-2005 10:55:58
I should also mention that when we let up on the clutch, hydraulic functions seem normal. How do we diagnose a broken feeder tube, or cracked housing? What is a carrier? Dealer and company engineers now suggest we use a clutch isolation tool to determine---what, I don't know? I am confused what we are looking for with this tool.
dwag
09-15-2005 18:29:29
 Re: 2390 hydraulics intermittant in reply to paulbick, 09-15-2005 14:49:28
Best way to check C1 would be to remove RPS valve and blow into C1 feeder tube with a rubber tipped air gun. You should have a positive seal, no leakage, air "deadheaded". Find someone locally that KNOWS CASE TRACTOR REPAIR, obviously not the dealer or their engineers that you are currently working with.
jim handke
09-14-2005 15:52:49
On dad"s 970, the oil distributer hub was shot. Also, the unit that has the three steel rings was badly worn. Same deal, dump the clutch and the three point and hydraulics would work.
big orange
09-14-2005 12:48:31
Did you replace the hydralic pump or the charge pump in the belly?It could be the charge pump if that wasn't replaced.
