2090 case
Rob
10-20-1999 09:07:03
540 p.t.o. not working feels like broken shaft or gear 1000 works o.k. possible problem???
can this all be accessed from main access plate at rear of tractor (mainly J.D.guy) not to familiar with repair and workings of Case;; yet!! any help would be appreciated THANX
Elmer
10-20-1999 16:39:38
 Re: 2090 case in reply to Rob, 10-20-1999 09:07:03
The 540 gear inside is keyed to the shaft. If you overload the pto in 540 it will shear. Early models were 3/16 key, later were 1/4 key. You have to remove pto assembly and dismantle. Not a real big deal. Remove side bolts from drawbar frame, but leave the front on each side and it will hang down. The rest is straight forward.
