Need Brake Seal Number
M5G
09-25-2005 17:43:31
I am in need of the seal number that seals off the oil from transmission to brake for a VAC Case. I have a number Chicago 22446 which when I ordered it (crossed ref) I received two different sizes of seals! A federal mongul number 472636 and a federal mongul 413247. Each is a different size!
Which is the right one? Thanks in Advance!
Paul f
09-26-2005 13:30:49
 Re: Need Brake Seal Number in reply to M5G, 09-25-2005 17:43:31
Different VACs had different brakes. If you have the disc brakes that required Seal VT3465 then CR 22446 is the correct number. (It crosses to National (450316) Shaft 2.25" Bore 3.251" O.D. 3.256"
The two national seals you listed cross to CR 22441 and 23742 respectively
